Old 01-04-2018, 08:05 PM   #1
Broomel
Default VVC160 starting problem.
Hi, I have just fitted my vvc160 and the modified mems 3 wiring loom into the mini.
With the ecu, 5as and fobs that came with the engine (presumed matched but I have never seen running ) upon selecting ignition the idle air control valve motor clicks as per normal but there is no cranking or fuel pump. The 5as repeatedly clicks in an alarm pattern.
I have tried re-syncing the fobs and new batteries but nothing happens.
Does anyone have any ideas? With the imob armed should it at least start and then cut out?
Thanks.
Sent from my HTC One mini 2 using Tapatalk
Old 01-04-2018, 11:00 PM   #2
You say you have tried to sync the fob but how have you done this?
First way is simply press lock 5 times then unlock.
Second is remove fob battery. Press both buttons together 5 times then replace battery.
Have you done both ways?
Old 03-04-2018, 08:07 PM   #3
Do you still have the decoder ring that fits around the ignition barrel?
Old 03-04-2018, 09:33 PM   #4
Broomel
I had not tried 5 locks then unlock however I've just tried and it doesn't make any difference.
Old 03-04-2018, 09:37 PM   #5
Broomel
Nope? Thought there was a receiver wire from the 5AS to pick up signal?
Down to one key fob now anyway and the retaining clip for the battery just snapped off one.
Old 04-04-2018, 09:40 AM   #6
Double check with the other guys. Its been a few years since i completed my wiring but I still have it
Sent from my SM-A520F using Tapatalk
Old 04-04-2018, 12:34 PM   #7
I don't have the ignition barrel ring thing on my mems3.
I have had that thing where the 5as goes nuts though, clicks on and off like mad for about 10 seconds, only happened a couple of times though. Turning the ignition off or and back on again or maybe disconnecting the car battery sorts it.
I have a battery breaker switch so it's normally off. Normally on powering up I get no noise from the 5as or led. Then after pressing lock on the fob 4 times it clicks and the led flashes, press unlock and it clicks again, led off, car starts.
Trying to start with 5as locked, it wont crank and no fuel pump.
Sounds like you may not have a matched set, have you got the 5as status flashing led wired up? Not needed but helpful.
Would be interesting to hear if anyone else had the 5as crazy on / off click, mine did stop after about 10 seconds but it's a little strange
Old 04-04-2018, 02:52 PM   #8
I know my mate Steve had a lot of issues with the immobiliser. I am sure the quick clicking was one of them.
I have swapped ECU sets on both MEMS 2 and MEMS 3 cars and the steering wheel ring has no part in the set.
I would try to borrow a known ECU set and try that. They don't like posting due to fragile components. Steve had 3 sets posted and only one worked. All claimed to be working when removed.
Old 04-04-2018, 06:47 PM   #9
Broomel
Thanks for the response chaps, it's not necessarily a quick clicking from the 5as but like a alarm horn speed, 20 seconds on then 20 seconds off.
Tempted just to send ecu to kmap for imob delete rather than trying to locate more fobs, ecu and 5as.
Old 04-04-2018, 07:07 PM   #10
Sound plan!
Old 04-04-2018, 07:08 PM   #11
Get an Emerald ECU! Problem solved!
Old 04-04-2018, 07:12 PM   #12
Broomel
Ain't got a never ending bank account like jackjewell93
Old 05-04-2018, 06:00 AM   #13
Before you do that, check the wiring, in particular the earth's. I remember Steve had many issues where a loose earth wire that seemingly did nothing, would actually go into the loom and then the system would work. All solid black wires are earth. There is a "bus" with about 30 behind the dash. One main connection to the body. Without that, almost none of the electrical circuits will run.
Just read your previous post on wiring. You were going to use a TF 160 loom. These have extra wires to a green multi plug. Not sure what these do as my only dealings with these are in a TF!
Old 05-04-2018, 07:52 AM   #14
jackjewell93
ECU: Emerald
Don't drag me into this mini has cleared me out I'm broke 🙄😂
Old 05-04-2018, 08:06 AM   #15
Broomel
As your minis melonsed already I can just use your emerald?
