Old 01-04-2018, 12:09 PM   #1
stun538
Default Mini cones on mgf / metro frame?
Hi just wondering if anyone is using rubber cones in a metro frame? Any pics would be a great help! I don't fancy coilovers or coil replacements. Sorry if this has been covered already but a search came up fruitless, thanks in advance
stun538 is offline   Reply With Quote
Old 01-04-2018, 01:49 PM   #2
Artstu
Artstu's Avatar
CC: 1275
ECU: Nissan Micra
I've never seen it done it either, however I think it's a good idea, oh and I hope you didn't spend 7 years building up to post that message
Artstu is online now   Reply With Quote
Old 01-04-2018, 11:04 PM   #3
My project Scorpion had this setup. I found it very bouncy. The shock absorbers were not good at all if you see my build diary
I can take some pictures if you like.
Old 01-04-2018, 11:24 PM   #4
it was bouncy, even after 5 pints of cyder,
i put it down to no engine over it,
Old 02-04-2018, 02:11 PM   #5
stun538
Haha more like 7 years building up to taking the grinder to my mini! Cheers for the replys, had a look at what terryG did to get the cones into the mg subframe and that's pretty much what I was thinking, always good to know someone has tried it first! Looks like you had some really bad luck with project scorpion AGoaty
Old 02-04-2018, 02:39 PM   #6
Yes, It's going to be sold on.
Shaun and myself drove around Devon for a night in Scorpion. As stated, it was very bouncy! I do put a lot of that down to the shack absorbers though. Maybe a matching pair rather than a bodged welded together affair would work better.
Old 02-04-2018, 04:27 PM   #7
stun538
Yeah hopefully with decent dampers and some weight in the front itll be ok. Cheers
