Old 01-05-2018, 02:56 PM   #31
Originally Posted by AGoaty View Post
Did you miss this bit!
"the ham fisted baffoon"
Itís not as if itís pain the ass to get off.
You must be curious exactly how that happened?
Old 01-05-2018, 03:20 PM   #32
Originally Posted by InstantCustard View Post
The multi function relay runs the fuel pump, starter solenoid, lambda and the ECU.
It’s a pretty big unit to forget
Mems3 so all the relays are in the fuse box, doesnt have an mfu
Old 01-05-2018, 03:51 PM   #33
Fair enough, glad they realised it wasnít reliable enough!
Old 01-05-2018, 04:14 PM   #34
I think the mfu was just a clump of 3 relays in a box.
Much better having separate accessible ones
Old 01-05-2018, 04:19 PM   #35
Yeah, I had one die on me years ago, expensive for a new MFU!
Old 01-05-2018, 08:54 PM   #36
My engines out of a TF and has the MFU, I think the later ZR's have them built into the engine bay fuse box with individual relays rather than 1 big 1.
Old 02-05-2018, 01:21 PM   #37
Yes I used the mgzr fusebox, it's very handy for power distribution to the in car fuse boxes via switched relays.
Main power leads I've only got battery to starter and one lead to fusebox, job done, everything else distributes from that. Making use of the outputs for the mgzr lights and abs to my in car power distribution (fuse boxes).
You can see the two black relays at the top of the pic, they are fed from the 40a abs fuse and 40a lighting fuse in the zr fusebox. They have their own built in fuses too, and supply a fuse box each in the car. The two 40a flat fuses you can see are 'igniton' and 'aux igntion' one powers my always live fusebox which in turn switches the other two on, also runs lights and ran fan manual override, things I want always on. The other one supplies the power to my airhorn relay.
The fuse box contains the yellow fuelpump, ecu, starter and rad fan relays, they are all the same so interchangeable.
Old 02-05-2018, 01:30 PM   #38
Like this
Old 02-05-2018, 06:41 PM   #39
jackjewell93
ECU: Emerald
Snapped the fuel rail by pulling to hard on the fuel hose broke the end off the rail
jackjewell93 is offline   Reply With Quote
Old 02-05-2018, 06:50 PM   #40
Pretty impressive! No need to take your frustrations out on other peopleís engines now!
Iíve been hanging off hoses trying to release them before, they can be a pain in the ass to get off sometimes, Iíve got a little hook tool that works well at getting underneath to break the seal, they usually come much easier then.
Old 02-05-2018, 07:48 PM   #41
"Iíve got a little hook tool that works well at getting underneath to break the seal, they usually come much easier then."
Is that how Michelle got pregnant?
Old 02-05-2018, 08:08 PM   #42
Iíve got a video somewhere that shows how Michelle got pregnant
Old 02-05-2018, 08:12 PM   #43
I've done this before!!!
Old 02-05-2018, 10:53 PM   #44
CooperWorks
Thumbs up
Now that I like.
I’ve got a video somewhere that shows how Michelle got pregnant
It's on xhamster if anyone wants a gander Search in the cuckold section
Old 03-05-2018, 12:17 AM   #45
[QUOTE=CooperWorks;378650]Now that I like.
You have got any room for that in your engine bay! plus it's Rover not Lotus!
