Old 28-10-2018, 11:13 PM   #31
Mark D
Mark D's Avatar
CC: lots
Hi guys, Iím back, sorry itís been festival season and just been really busy jet setting with various bands. Iíll make some more spacers up, if Atchi can still cut the plates, but like to do them in a batch if possible. They are currently working out at at £160 a pair and i intend on starting them in Dec so get your orders in please.
Old 28-10-2018, 11:20 PM   #32
Mark D
Mark D's Avatar
CC: lots
Mm man you won’t overdo the shaft by over tightening the nut, you will seriously reduce the bearing life though. I just usually nip the nut up so it’s tight then back it off a bit.
Old 29-10-2018, 07:40 PM   #33
mm man
Originally Posted by Mark D View Post
Mm man you wonít overdo the shaft by over tightening the nut, you will seriously reduce the bearing life though. I just usually nip the nut up so itís tight then back it off a bit.
Nice one Mark will do thanks very much
Old 02-11-2018, 12:03 AM   #34
wee man
wee man's Avatar
Your mini is back up for sale mark
12.71@108.44
Old 02-11-2018, 12:50 PM   #35
ROCK,N,ROLL !! are you turning hippie ? Lol change your life with awkward drummers , get alesis dm5 , only use kick drum and snair samples , will save your brain and stress ,
https://youtu.be/14GYov0EdyQ
