Old 21-11-2010, 07:23 PM   #31
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
Originally Posted by Coupe View Post
No you shouldn't have - the issue I have is that the weller motorsports curve inwards sharply where they meet the rim so they have less clearance than most wheels.
thats good then, thought id messed up for a minute then
miniwade is offline   Reply With Quote
Old 29-11-2010, 06:43 AM   #32
Shalma
Informative car sharing
Shalma is offline   Reply With Quote
Old 29-11-2010, 07:56 PM   #33
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
little up date engine bay is pretty much ready for paint and then i can start to build back up for the last time
also the engine is all together less the alternater.
Old 29-11-2010, 08:07 PM   #34
Dodger
Dodger's Avatar
CC: Type R
ECU: Hondata S300
Hi Miniwade. Very nice build so far..
Looking forward to seeing it on those wheels.
Question - what is the length of your TB from the head to the bellmouth?
Cheers Dodge
Re-build diary starting soon[/COLOR[/COLOR]] - Rust never sleeps does it!!!
Dodger is offline   Reply With Quote
Old 29-11-2010, 08:19 PM   #35
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
Cheers Dodge
yeah will do no probs, when you say bellmouth do yo mean the end of the trumpet?
Old 29-11-2010, 10:06 PM   #36
Dodger
Dodger's Avatar
CC: Type R
ECU: Hondata S300
yes - trumpet.
Old 29-11-2010, 10:23 PM   #37
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
yes - trumpet.
just niped to my shed for you and its 29cm i could probably reduce that by around 2/3cm in needed but i think i should be ok
Old 29-11-2010, 11:05 PM   #38
Dodger
Dodger's Avatar
CC: Type R
ECU: Hondata S300
Thanks for popping out to the shed in this weather
Thats actually a pretty good length. Did you have to cut that amount out of the bulkhead because they are straight (as they should be) or are you allowing for quite a deep airbox? From what I can gather 25mm over the trumpets would be a minimum.
I am thinking of ITB's but don't want to cut the bulkhead (if possible) on my replacement shell.
Cheers - Dodge (Ian)
Old 29-11-2010, 11:13 PM   #39
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
no probs mate,
i have cut quite a bit out of the bulkhead to allow for them (hope its enough)
not sure what to do filter wise yet
pic of what i have cut out
Old 29-11-2010, 11:28 PM   #40
sirkieran_1986
Very nice think of doin this to mine r superchange . Can not make my mind up . How think is that steel u have used on bulk her 1.6 r 2mm ?
sirkieran_1986 is offline   Reply With Quote
Old 30-11-2010, 09:37 AM   #41
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
not sure on what thickness it is but was thicker than what i cut out so would guess at 2mm.
if my car doesnt make 160+bhp i will be disapointed and will eiher put a b18 in it or supercharge what i already have. i just want to get the car altogether first then i can swap and build the perfect engine to suit my needs which will be trackdays and a little blast on a weekend, i wouldnt turbo it though as i think that would be the wrong application for what im trying to achieve.
Old 30-11-2010, 12:40 PM   #42
sirkieran_1986
Good luck . I have a b16a2 engine in mine runnin lots of skunk 2 parts . 172bhp . So yrs should be around the same plus more with sum luck . If I win lottery this winter will be supercharging it and remapable ecu system too . =}
Old 30-11-2010, 11:38 PM   #43
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
supercharging would be my preference as its alot smother power delivery unlike turbos which come on boost then break traction which i dont think the mini will have any problems doing without a turbo so god knows what it would be like with one.
as said if i make 160 ish bhp i will be happy
Old 06-12-2010, 07:53 PM   #44
miniwade
miniwade's Avatar
CC: B18 c6
ECU: dta
little update
i have managed to drop the engine in and test fit to see everything is going to clear and thankfully its as it should be, even the aftermarket manifold will clear which i wasnt expecting so thats a bonus,
also my alloy fuel tank has arrived and collected my fibreglass doors so plenty to get on with now, just wish the bloody weather would warm up a bit
a few pics
and one of the the drivers door fitted
now i know everything is all clear i can take it apart and get the bulkhead ready for paint
Old 06-12-2010, 09:03 PM   #45
ad53ggz
ECU: rover until i can get some
Send a message via MSN to ad53ggz
Nice looking build!
ad53ggz is offline   Reply With Quote
