#106 |
CC: 1.6
ECU: Bone stock
#107 |
CC: 1.6
ECU: Bone stock
#108 |
CC: 1998.2
ECU: honda stock
I know you feeling good right now.
at Pod' ran 11.2 @ 122mph allmotor 1.5 60ft at pod. now building a mini http://www.youtube.com/watch?v=UzbJtb_VZ9c |
#109 |
I see back, you wander about a scoop in hood for air feed,
Can't you just cut a hole and fit a air damm so hood fit down proper,
#110 |
CC: 1.6
ECU: Bone stock
ive been looking for hood scoops online and I just havn't found one that goes with what I have pictured in my head
im still looking but for now i'll run a lifted bonnet the list is getting so small now, I cant wait to get behind the wheel and hear the engine come to life I got my shock brackets in last night from dhl also |
#111 |
CC: 15
Can you not get the sock type air filter sits a lot lower
#112 |
CC: 1.6
ECU: Bone stock
an air box is on the list of parts, but i have those filter sockets now, so i will run them until the air box comes up higher on the list or when i save up the $$ for it
i got the sockets from Alvis with the engine |
#113 |
CC: 1.6
ECU: Bone stock
http://www.amazon.com/Pickup-Suburba.../dp/B006X8AVG6
i think im gonna go with this grill for the clubby cut the lenght down on it for the width of the clubby just need to find out if i can have the grill sit over the headlights for MOT or not |
#114 |
CC: 1.6
ECU: Bone stock
anyone need any T reg micra parts?
1.0l 5speed, 112k miles on the engine, not sure the shape of the box right now but it still goes into gear and drives forward (off the road to the side, lol) ( not leaking oil) the engine runs great, did a few trips to Germany with no problems out of it have a good night |
#115 |
CC: 1.6
ECU: Bone stock
#116 |
CC: 1.6
ECU: Bone stock
#117 |
CC: 1.6
ECU: Bone stock
![]() ![]() ![]() wipac h4 headlights, wired in some relays and then after I did that I started to have some electrical bugs in the system the turn signals and hazards would stop flashing when the headlights were on and the horn wouldn't make any sound i burnt up one of my flashers, so i got a heavy duty one now after about 2 days of messing around with the wiring, it turned out to be a ground problem, re-made my ground wires and now its good im gonna wire up my headunit tonight and bolt in the cluster and then the dash will be in for its last time the car is getting close but i have so many small details to work out still i got metal to cover up the old shifter hole... |
#118 |
CC: 1998.2
ECU: honda stock
Soon I'll hear is coming donw the street. Right ? Befor I leave.? Lol
#119 |
CC: 1.6
ECU: Bone stock
when do you leave?
june right? |
#120 |
CC: 1998.2
ECU: honda stock
Yes
Thread Tools | |
Display Modes | |
