#226 |
CC: 1.6
ECU: Bone stock
#227 |
CC: 1.6
ECU: Bone stock
![]() ![]() ![]() here is my temp plan of mounting the stock Honda del slow pedal box, booster, master cylinder into the shell its temp mount so that I could make sure I like the location of the pedals and how they feel when pushing the pedals from my drivers seat today I'm going to work on rebuilding that corner of the firewall box |
#228 |
CC: 1.6
ECU: Bone stock
![]() ![]() spent a few hours on sheet metal work for the firewall the left side of the firewall box is going to hold the underhood fuse box |
#229 |
CC: 1.6
ECU: Bone stock
I now have a Honda del slow steering column installed into my shell,
I had to section the steering column 4 inches, and I mounted it to my dash bar the dash bar is 2 inches rearward |
#230 |
CC: 1.6
ECU: Bone stock
#231 |
CC: 1.6
ECU: Bone stock
#232 |
CC: 1.6
ECU: Bone stock
![]() ![]() I have to get a trans cooler, and then i'll be ready to turn the motor over wiring is almost done I got a 20 pin cannon plug for the front clip I need to wire up the front lights, rear lights, fog lights front and rear, fuel pump/fuel level sender and finish installing the main battery cable that goes to the rear and make a battery mount |
#233 |
CC: 1.6
ECU: Bone stock
http://www.technoversions.com/MeterMatchHome.html
I found this here in the states, going to be way cheaper Then buying it from that guy in the UK It’s $45 USD plus a few more bucks for shipping |
#234 |
CC: 1.6
ECU: Bone stock
worked on wiring today and I got my throttle cable in the mail
the front clip wiring is done I used 18 pins out of a 20 pin cannon plug my throttle cable is from a gen 1 Honda odyssey van(95-9 ![]() I guess the cable bracket is in different spots on the intake manifold because I need to ext mine out about 2.5-3 inches....no biggie not bad overall, I paid 20 USD for the cable from rockauto and from what I have seen online, they want 50 USD for rhd throttle cables ![]() |
#235 |
CC: 1.6
ECU: Bone stock
only thing I did on the mini today was make a new throttle bracket
I just started over from scratch ![]() |
#236 |
CC: 1.6
ECU: Bone stock
#237 |
that good, auto tranny will be nice, did you get your speekers banging out in workshop yet,
#238 | |
CC: 1.6
ECU: Bone stock
![]() Quote:
I'm trying to add another amp to the amp rack trying to buy a used crown ce1000 power amp summer time here gets to around 46C or so the monster size trans cooler will help a lot |
#239 | |
![]() Quote:
i cant hear the diferance on big punch base stuff but can in studio when mix and monitor, i paid 400 for a qwuad amp and it dont even have any e,q changers, its honist i think, what did the standerd honda have for tranny cooling? we had exstra small tank at bottom of rad joined in, qwite neet!!
#240 | |
CC: 1.6
ECU: Bone stock
![]() Quote:
I have a Samson dual mono servo amp for my turntables to play music with in my computer room, with some small JBL 2 ways |
Thread Tools | |
Display Modes | |
