Old 26-01-2014, 08:44 PM   #76
mm man
Originally Posted by kcchan View Post
I was tempted to do a rear disk conversion. What does the assembly or just disks and calipers weigh?
Hi kcchan
Hope this helps, the total weight of the disc/Suzuki hub/caliper is 738g
Sorry but I couldn't tell you what the mini set up weighs
Old 26-01-2014, 10:36 PM   #77
Oooo!
That Minus looks nice.
What alloy wheels are they?
Can you use rear seat with front seat you got?
Atchi
Old 27-01-2014, 09:10 PM   #78
mm man
Originally Posted by miniswift View Post
Oooo!
Atchi
12" compromotive late 70's early 80's
Yes you can I used to take my two boys regularly to shows when they were younger. You wouldn't want to put a rugby player in there though
Old 10-02-2014, 07:01 PM   #79
mm man
Another quick update
Got around to fitting the exhaust manifold but now have to do a quick mod to the subframe as its sitting too close
http://s1105.photobucket.com/user/mm...?sort=6&page=1
Also fitted ford competition studs
I also managed to pick up one of these and this will be a project for another day
Old 10-03-2014, 10:00 PM   #80
mm man
Been doing a bit of work on the flip front, have got some clearance issues but nothing that can't be sorted with a grinder, welder and some fibreglass, also attaching some galvanized steel locking/aligning side supports
I have decided to go with the steel van/pick up grille
(Just some of the photos)
To see the rest of the flip front album and the work I've been doing on this follow the link below
http://s1105.photobucket.com/user/mm...?sort=6&page=3
Old 12-06-2014, 11:22 AM   #81
Jonny f
Looking good as ever!
Jonny f is offline   Reply With Quote
