Old 22-04-2012, 08:19 PM   #31
mm man
Hi quick update see links below
Looks like good news offered up engine and subframe to body (roughly) to see if i had any issues with height (as previously mentioned in this topic) A few people on here including my self weren't sure if it would fit without heavy modifications to bonnet. As you can see from photos HAPPY DAYS !!
http://s1105.photobucket.com/albums/...%20to%20minus/
done a bit on the suspension refurbing hubs ready for new bearings
http://s1105.photobucket.com/albums/...ame%20rebuild/
Finally for now just purchased 4 to 1 manifold from instant custard (thanks by the way) Cleaned up nicely ready to fit
http://s1105.photobucket.com/albums/...st%20manifold/
Slowly but surely bit by bit !
Old 22-04-2012, 09:05 PM   #32
blue blood
Is the bonnet new?
Regards Blue
blue blood is offline   Reply With Quote
Old 22-04-2012, 09:49 PM   #33
mm man
Yes it's a genuine new one that come with the car years ago . Can i ask why?
Old 22-04-2012, 11:05 PM   #34
blue blood
I was just wondering where you got it from? and how much it cost?
Regards Blue
Old 29-04-2012, 09:26 PM   #35
mm man
Can this guy help? If you need one
http://www.minus-cars.com/index.html
Old 04-06-2012, 09:01 PM   #36
mm man
Update on Progress more photos added to Suspension Subframe rebuild front hubs now completed
Refurbished rear subframe extended back brace to clear fuel tank also started rear disc brake conversion to suzuki rear hubs and discs
http://s1105.photobucket.com/albums/...20Sub%20Frame/
Old 24-06-2012, 05:19 PM   #37
mm man
Updated photo link to flip front basically bonded minus bonnet to wings to make a one piece unit prior to fitting mini tech hinges (next job)
http://s1105.photobucket.com/albums/.../Flip%20Front/
Old 24-06-2012, 10:06 PM   #38
blue blood
love the update. I really like this project very unique Regards Blue
Old 14-07-2012, 07:38 PM   #39
mm man
Thanks blue ill try to keep the updates coming. A bit slow i know but plodding along ,
flip front
cut out sender unit/ pump from suzuki tank
http://s1105.photobucket.com/albums/...20fuel%20tank/
Old 18-07-2012, 09:33 PM   #40
charlie_t
if you copy and paste the img code and paste it here
You can't polish a turd but you can roll it in glitter
charlie_t is offline   Reply With Quote
Old 03-10-2012, 04:39 PM   #41
alun
Hi ,
nice car,
do u know of a mini/susuki subframe for sale?
Thank you.Alun
alun is offline   Reply With Quote
Old 02-12-2012, 09:37 PM   #42
mm man
Sorry Alun I dont know of any subframes most people on here make their own
Old 02-12-2012, 09:47 PM   #43
mm man
Been a while since I've managed to do any work on the car, just started again here are the latest photo links to work carried out on fuel tank + the last 4 photos on the sub frame show a modification I've had to make more clearance for the driveshafts, it was a little bit too close
Fuel Tank plus Pump and sender unit
http://s1105.photobucket.com/albums/...sender%20unit/
Sub Frame (Last 4 Photos)
http://s1105.photobucket.com/albums/...cpZZ6QQtppZZ24
Suspension Re-build (last 4 photos)
Old 03-12-2012, 09:34 PM   #44
Phatwiji
Phatwiji's Avatar
I have to thank you for all the photos you have of your subframe, they were most useful when it came to building my frame (that is not totally finished yet I think.). Looking at your latest post and pic's I think I may need to make some mods when it comes to the drive shafts, I was half expecting this anyway. But well done, good work and thanks again!
Will.
Phatwiji is offline   Reply With Quote
Old 05-12-2012, 10:32 PM   #45
mm man
Hi Will
Thanks very much for your comments and I am glad that the photos have helped you. When I started my build and was looking at what others had done and i found a lot of photos had been removed on the earlier build diaries I think it was something to do with forum update over the years (sorry if that's incorrect) anyway so I decided to post as many photos as I could as I think pictures can help much better than words can, well my words anyway. Good luck with your build looking good I see you are going great guns at it and will be finished way ahead of me. So I may need to come to you for help when I get to another problem , that's the great thing about the forum theirs always some help somewhere or from someone. Thanks again
