Old 11-02-2018, 08:54 PM   #1
lsdweb
CC: 1293
ECU: Emerald
Default B18 engine mount
Hi All
I'm getting closer to dropping my B Series engine into my shell. I have one of Keiran's subframes but I think I have the wrong nearside engine mount (photo below)
I've seen plenty of what look like the correct mount online but I'm not sure what to look for - do I need to change just the part with the rubber bush or does the steel ( 2 bolt) bracket need changing too?
Thanks
Wyn
lsdweb is offline   Reply With Quote
Old 12-02-2018, 02:55 AM   #2
Bennjaminozhonda
That’s likely a liquid filled damper from a 96-00 b series chassis (ek series)
You can swap out the mount and engine brace from either and earlier 92-95 EG chassis B series or 96-00 DC b chassis
Bennjaminozhonda is offline   Reply With Quote
Old 13-02-2018, 10:42 PM   #3
lsdweb
CC: 1293
ECU: Emerald
Originally Posted by Bennjaminozhonda View Post
Thatís likely a liquid filled damper from a 96-00 b series chassis (ek series)
That's great - thanks.
