Old 07-10-2012, 08:12 AM   #991
Burnards latest modification:
Old 07-10-2012, 09:13 AM   #992
Burnard
Burnard's Avatar
Send a message via MSN to Burnard
i considered putting in my dads car, but it looks good there.
Originally Posted by InstantCustard View Post
If the price is right and you stick to your word, I'd give you a go!
Burnard is offline   Reply With Quote
Old 07-10-2012, 10:21 AM   #993
And I'm supposedly the lazy strawberry!
Old 13-10-2012, 09:34 PM   #994
Burnard
Burnard's Avatar
nice sig...
Old 15-10-2012, 04:53 PM   #995
kappa3
CC: 1600cc
Hi mate, I just wanted to ask I am looking to do a similar conversion to mine, but with a added turbo, but my question is where have you positioned your coil for the dizzy, as I cannot see it in the pictures?
kappa3 is offline   Reply With Quote
Old 15-10-2012, 06:27 PM   #996
charlie_t
passenger side inner wing
You can't polish a turd but you can roll it in glitter
charlie_t is offline   Reply With Quote
Old 16-10-2012, 05:32 PM   #997
Burnard
Burnard's Avatar
spot on, passenger side wing, just in front of the red bit that holds the bonnet on
I would love to see some more pics of your turbo manifold kappa3, i am considering turbo'ing this....
Gotta keep up with mustard somehow....
Old 16-10-2012, 05:35 PM   #998
kappa3
CC: 1600cc
Hi Burnard, I have got a build thread started have a look:
http://www.16vminiclub.com/forums/sh...ad.php?t=30809
Oh the title is: 'E16SE turbo'
Bobby
Old 16-10-2012, 05:39 PM   #999
Burnard
Burnard's Avatar
just found it mate thanks
Doesnt look toooo complicated... lol. just means i need to swap to an injection setup
Old 16-10-2012, 05:43 PM   #1000
Good luck with that.
Old 16-10-2012, 05:47 PM   #1001
kappa3
CC: 1600cc
yeah basically that is it, but not sure if the turbo will be ok to run on standard internals or would I need to upgrade these?
The manifold is off a 1.0ltr nova, as this one is slightly higher than the the one for the e16se, so it will not foul with the subby.
The only problem is to see if it will fit in the car with the elbow and exhaust down pipe, I am putting it in my clubby estate though, so bit more space than the usual round nose.
Old 16-10-2012, 06:07 PM   #1002
Burnard
Burnard's Avatar
Im not sure it will fit, but many people leave the turbo's hanging out the front (looks cool imo)
Personally, i would make a totally new custom manifold like a lot of people have done before, meaning you can mount the turbo higher up, and even closer to the block. and you can also angle it in any way you like, so long as you have the tools it wouldnt even be that expensive to do.
Engine internals wise... i dont have a clue, shouldnt be a problem if its in good working order and the compression ratio is correct. but dont run tooo much boost though, else you might blow the welds in the intake.... (FF1 quote for ya... not serious)
Old 16-10-2012, 06:09 PM   #1003
You'll probably want to lower the compression if your running standard internals and I wouldn't wanna risk running big boost.
Old 16-10-2012, 06:14 PM   #1004
kappa3
CC: 1600cc
What is the best way to lower compression for these engines?
Does anyone know?
Please help
Old 16-10-2012, 06:17 PM   #1005
kappa3
CC: 1600cc
In regards to making a manifold for this, what metal is the best to use for this, I may make a trial unit and then get it made professionally seam welded, as my welding skill are not the best
